BookmarkSubscribeRSS Feed
clark_woo-seag_
Jun 23, 2011
Text File save No labels
I want to save text file with no Label
but I can't find option for no label
dt=open("d:\aa.txt", End of Field(comma), Labels(0),
columns( aa=character(100) ));
dt<
Please let me know how to use save option.
Re: Text File save No labels
I thought this was going to be an easy one, but it seems to be a little more involved than I'd expected. What you need to know is what all the options are for the save command - and my manual isn't very informative on that, so what I'd normally do next is to run the command interactively and inspect the code that's been automatically generated as a result. However although I can load data from a text file and look at the resulting script associated with the resulting data table (it's shown below) to show a list of the various choices I can make, I can't find a way to do the same when exporting data to a text file. So how do I find out what all the options are for the save command? Anyone?
style="font-size: 9pt; font-family: "Courier New"; color: black;">
style="font-size: 9pt; font-family: "Courier New"; color: black;">dt
style="font-size: 9pt; font-family: "Courier New"; color: navy;">=
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Open
style="font-size: 9pt; font-family: "Courier New"; color: black;">(
style="">
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"d:\aa.txt"
style="font-size: 9pt; font-family: "Courier New"; color: navy;">,
style="">
columns(
a
Numeric
b
Character
c
Numeric )
style="">
Import
Settings(
style="">
End
Of Line(
CRLF
CR
LF )
style="">
End
Of Field(
Comma )
style="">
Strip
Quotes(
style="font-size: 9pt; font-family: "Courier New"; color: teal;">1
style="">
Use
Apostrophe as Quotation Mark(
style="font-size: 9pt; font-family: "Courier New"; color: teal;">0
style="">
Scan
Whole File(
style="">
Labels(
style="">
Column
Names Start(
style="">
Data
Starts(
style="">
Lines
To Read(
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">All
style="">
Year
Rule(
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"10-90"
style="">
style="font-size: 9pt; font-family: "Courier New"; color: black;">)
style="font-size: 9pt; font-family: "Courier New"; color: navy;">;
style="font-size: 9pt; font-family: "Courier New"; color: navy;"><<
save(
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"d:\aa2.txt"
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">show
properties
style="font-size: 9pt; font-family: "Courier New"; color: black;">dt)
ms
Jun 23, 2011
In the menu Preferences/Text Data Files you can you can change the export settings. There is check box for including labels, make sure it is not checked. This of course affects all files.
That'll solve the immediate problem, I'm sure - many thanks! To do that in code, the necessary option can be found by running "show preferences(all)" and looking in the "Export Settings" section.
The following should therefore answer the original question about how to export without labels - the first export leaves them out, whereas the second one includes them:
Preference(Export Settings(Export Table Headers(0)));
dt << save("C:\File0.txt", text);
Preference(Export Settings(Export Table Headers(1)));
dt << save("C:\File1.txt", text);
Message was edited by: David Q/R
