I am still fairly novice with JSL but I am looking to generate a table using all the columns in a file as grouping columns, where the script will select all the columns in the file vs. having identify each column name in the script. Reason being is that the column names can change from split table to split table and I want a script that will be generic enough to handle this. Here is an example of the script I am using now
// Open dialog box to select SWR Table
project << Run Script(
Files = Pick File( "Select SWR Table", "$DESKTOP", {"JMP Files|xlsx", "All Files|*"}, 1, 0, "", "multiple" );
For( i = 1, i <= N Items( Files ), i++,
Try(
Open(
Files[i],
Worksheet Settings( Has Column Headers( 1 ), Number of Rows in Headers( 1 ), Headers Start on Row( 1 ),
Data Starts on Row( 2 ) )
Bring Window To Front
//Create SWR Table - TBD
obj = Tabulate( Add Table( Row Table( Grouping Columns( :WAFER, :EPI Run ) ) ),Include missing for grouping columns(1) )
I want to substitue out the individual columns in "Grouping Columns" to use all the columns from the table without having to specify each one. Is this possible?
