T test
Hi everybody ,
I just want to know if the jmp  SW built-in functions allow you to specify whether the datasets are heteroscedastic (different σ) or homoscedastic (equal σ).
What are the steps i need to do to determine if both the populations have equal varaiance or not?
Thanks
Re: T test
It is an option under the Fit Y by X(Oneway) analysis
You could have found this by searching th Statistics Index for it
Re: T test
Adding to Jim's help, choose Pooled t if the variances are not different or t Test if they are different.
Re: T test
Re: T test
Re: T test
Thank you
