ellen_cain
System.Reflection.TargetInvocationException
Hello, has anybody else encountered the error below before?  If yes, how did you troubleshoot?  I desperately need a quick resolution.
JMP has experienced a problem and must now terminate:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation.
Additional information about the problem will be written to "C:\Users\Z656540\Documents\JMPManagedExcept 2015-07-30T16-39-35.txt" if possible. Please contact JMP Technical Support to report this problem so that it can be investigated.
Exception Stack Trace:
   at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
   at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
   at System.Delegate.DynamicInvokeImpl(Object[] args)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
<Truncated>
stan_koprowski
Re: System.Reflection.TargetInvocationException
It might be best to let Tech Support take a look at this. It will help if you can include an example to reproduce the problem.
Thanks,
Stan
Ravikanth
Hello Stan,
I am also facing the same issue. Could you please help me in resolving this issue. JMP issue.PNG
FYI: OS which I am using is Win10.
Version of JMP: 13.1
By reading the error messages issued by Ellen and yourself, the errors have occurred for completly different reasons.
You need to contact JMP Support too:   email:  Support@jmp.com
