joydeepb83
Select and color rows
Hi I am writing the following code to achieve the following. Could anyone please help. For some reason the code is not working.
Thanks Joydeep
Objective.
I am opening Table 1, Then getting summary of Table 1 and save it to table 2.
Now for each row in the Table 2, I want to color the rows of Table 1.
So I am running For loop in Table to select each row and based on that trying to color the row of Table 1.
I would appreciate your help.
//// Here is the code I am trying
dt10= open("\\Test\Table1.jmp");
dt11= dt10 << Summary(
Group(:Work Week ),
Freq( "None" ),
Weight( "None" )
x= N Row(dt11);
v= N Rows(dt10);
For(i=1,i <=x, i++,
dt11 << Select Rows(i) ;
For (j=1,j<=v, j++, dt10 << current data table();
if ( Row State(dt10,j) == "Selected" , Column( dt10, "Work Week") << Color Cells( i,{j} ));
dt11 << clear selection();
Re: Select and color rows
Try this:
dt10 = Open( "\\Test\Table1.jmp" );
dt11 = dt10 << Summary( Group( :Work Week ), Freq( "None" ), Weight( "None" ) );
x = N Row( dt11 );
v = N Rows( dt10 );
For( i = 1, i <= x, i++,
	dt11 << Select Rows( i );
	dt10:Work Week << color cells( "Red")
Try this:
x = N Row( dt11 );
v = N Rows( dt10 );
