Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Thank you. This works for me. Is there a function similar to "set table variable" which sets the value as a global variable? (:: instead of :) I am having to take the table variable and save it as a global variable to do my calculations.
If you want to do this without using a script, first select the rows (using whatever method you want). Then, under Rows-Select-Name selection in column, you create a column of 0 and 1 that identifies the selected rows. Then create a new column using the Column Sum formula and put the newly created Named selection in column as the By variable. The result will show the sum for the selected and unselected rows.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '66898' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '66898') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '66898') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
