This website uses Cookies. Click Accept to agree to our website's cookie use as described in our Privacy Policy. Click Preferences to customize your cookie settings.
Created:
Aug 9, 2018 02:16 PM
| Last Modified: Aug 9, 2018 11:16 AM(8574 views)
| Posted in reply to message from txnelson 08-07-2018
Thank you. This works for me. Is there a function similar to "set table variable" which sets the value as a global variable? (:: instead of :) I am having to take the table variable and save it as a global variable to do my calculations.
If you want to do this without using a script, first select the rows (using whatever method you want). Then, under Rows-Select-Name selection in column, you create a column of 0 and 1 that identifies the selected rows. Then create a new column using the Column Sum formula and put the newly created Named selection in column as the By variable. The result will show the sum for the selected and unselected rows.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '66898' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if (newSub.getAttribute("slang").toLowerCase() == code_l.toLowerCase()) {
if (value == '66898') {
else{
} else {
sub_L = newSub.innerHTML;
try{
catch(e){
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
