vince_faller
Stop sorting of Process screening table with auto recalc on
Is there a way to have the process screening table NOT sort by stability index and the last column sorted when auto recalc is on?  Once I exclude something the entire table resorts.  It's a good feature but I'd like to turn it off in some cases.  See below.
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
ps = dt << Process Screening(
   Y( :weight ),
   Grouping( :sex, :age ),
   Minimum Process Length( 1 ),
   Automatic Recalc(1),
   Control Chart Type( "Indiv and MR" )
tbl = Report( ps )[Table Box( 1 )];
tbl << Sort by Column(1, 1);
tbl << Sort by Column(2, 1);
wait(2);
dt << Select Rows( [5, 7, 8, 10] );
dt << Exclude(1);
dt << Clear Select;
Vince Faller - Predictum
