eschares
Stacked Pareto
I am hoping someone can help me figure out how to make a stacked pareto chart.
I have data on requests made by department over a 5-year period. I would like to build a chart that shows the number of requests by department, with each departmental bar stacked with yearly data.
I can make the following chart in Graph Builder, but can’t get the x-axis to reorder Ascending->Descending by bar height:
I can get this chart from Analyze->Quality & Process->Pareto, but can’t get the bars to show stacked Year data within the bars.
Is there a way to combine these two? I’ve explored the JMP user discussion boards but couldn’t find an answer.
I did see the similar post at https://community.jmp.com/t5/Discussions/How-to-create-a-stacked-pareto-chart/m-p/6506#M6500 but it didn't answer my question as to *how* to make it.  The accepted solution doesn't look sorted by any discernable value, and all stack to 100% which is not what I want.
eschares
Re: Stacked Pareto
I updated from JMP 12.0 to 14.1, and it now has an option on the x-axis to Order By. Got it!
eschares
Re: Stacked Pareto
