David_Burnham
Source Code Documentation
I currently use NaturalDocs to automatically generate HTML-based documentation of the JSL code that I write.  I works fairly well with simple comment-markup within the code:
I'm currently setting up a new dev environment and it's an opportunity to review the tools within my workflow.  I just wondered if anyone has any other thoughts on documentation-generation tools for JSL?
-Dave
ih
Super User (Alumni) ih
Re: Source Code Documentation
I started down this path with DOxygen (I use a spin off, roxygen2, extensively in R) but didn't get far enough to deploy anything with JSL. NaturalDocs seems like a good fit.
pmroz
NaturalDocs looks very interesting.  Thanks for making us aware of it!
Slight branch to this discussion: here are some open source utilities that I find indispensable for program development:
TortoiseSVN: Helps programmers manage different versions of the source code for their programs (source code control system).  Apacheā„¢ Subversion (SVN)Ā® client, implemented as a Windows shell extension.
Notepad++: Windows Notepad on steroids.  Syntax colorization for most languages.
Kdiff3: Windows-based diff program.  Great for finding and merging differences between two or three files or directories.
uday_guntupalli
Level VIII
@David_Burnham,
       I tried to take cue and install Natural Docs. After setting it up the way detailed here (http://www.naturaldocs.org/getting_started/getting_set_up/#starting_a_new_project) , when I try to run configure to generate documentation , I get the follow ing
However, as instructed , I did provide the input folder and output folder - Any thoughts on what I did wrong ?
Best
Uday
David_Burnham
@uday_guntupalli I'm going ahead and installing it on a new computer.  I'm happy to document and share the procedure once it's complete it(I had to extend the configuration to handle the JSL language).
-Dave
David_Burnham
I've just installed on a new PC - attached is a description of the process
-Dave
