Thanks guys for your support!
I have attached both figures (standardized and non-standardized) to see the differences between them.
I'm using JMP 13.2.1 (32-bit).
Jeff, That's true. Each legend is a color code for each column. So if I want a standardized figure, I can't get a single legend.
Maybe, I just use the standardized heatmap with the legend from the non-standardized heatmap together. In that case, I will have the figure that I want with a single legend which contains the whole range of the color codes. It might not look proffessional though, but I think that's what people do!
Thanks.
