matth1
Show labels for selected rows only
In Graph Builder, I want to show a data label (not a hover label) for selected rows only. As a demo, I tried the following code:
Try(
	Show( dt:Selected Name ),
	dt << New Column( "Selected Name",
		Character,
		Set Formula( If( Selected( Row State( Row() ) ) == 1, :name ) )
dt:Name << Label( 0 );
dt << Clear Row States << Select All Rows << Label << Clear Select;
dt:Selected Name << Label( 1 );
// The following doesn't work as expected
gb1 = dt << Graph Builder(
	Variables( X( :height ), Y( :weight ) ),
	Elements( Points( X, Y, Legend( 3 ) ) ),
		Dispatch( {}, "Graph Builder", FrameBox,
			{Marker Size( 5 ), Marker Drawing Mode( "Normal" )}
nw1 = New Window( "DTB", dtb1 = Data Table Box( dt ) );
dtb1 << set selectable rows();
When I select a row in the data table, or from the table box, or by selecting the data point in the Graph Builder, it should show the label in :Selected Name. However, it always seems to be one selected point behind! For example, I select KATIE and the data point is highlighted but there's no label. Then if I select LOUISE, the data point for that row is highlighted, but the data point for KATIE is now labelled!
But if I click LOUISE again, it becomes correctly labelled:
Finally, if I deselect all rows then the last label remains visible.
Interestingly, if I use the following code to put the table box and graph builder in the same window, and select rows from the table box or the Graph Builder plot, it works as expected, with the label only showing for the selected rows:
dt << clear select;
nw2 = New Window( "Demo",
	H List Box(
		dtb2 = Data Table Box( dt ),
		gb2 = dt << Graph Builder(
dtb2 << set selectable rows();
Is there a better way for doing what I'm attempting?
I see this behaviour on JMP 17.2 and JMP 18.
Re: Show labels for selected rows only
I think you might have to use something to cause a small delay. One option is row state handler (these can be very unreliable) + run formulas
Try(
	Show(dt:Selected Name),
	dt << New Column("Selected Name",
		Character,
		Set Formula(If(Selected(Row State(Row())) == 1, :name))
dt:Name << Label(0);
dt:Selected Name << Label(1);
	Show Control Panel(0),
	Variables(X(:height), Y(:weight)),
	Elements(Points(X, Y, Legend(3))),
		Dispatch({}, "Graph Builder", FrameBox, {Marker Size(5), Marker Drawing Mode("Normal")})
nw1 = New Window("DTB", dtb1 = Data Table Box(dt));
f = Function({a},
	dt << run formulas;
rs = dtb1 << Make RowState Handler(f);
matth1
Thanks for the suggestion! Unfortunately it didn't work for me as is, but the following does:
f = Function({a},
	rr = dt << get selected rows;
	dt << clear select;
	wait(0);
	dt << select rows( rr );
	rs = dt << Make Row State Handler(f);
However, it feels like a horrible workaround. The Make Row State Handler statement inside the function seems to be necessary because after the first call of f() the handler gets forgotten (not sure I understand what's happening here!).
It doesn't work with the code I provided or when using similar idea on your data (for me it works using JMP17.2/JMP18.0 on Windows 10)?
matth1
Your simple function using << run formulas doesn't work for me in JMP 17.2/18.0 on Mac OS 13.6.7.
