antoinesofradir
[Jsl] How can i stop a script with a button ?
Hello ! I have a problem (again !)
I would like to close my window thanks to a button box and stop my script.
I used this :
nw = New Window( "Window",
  V List Box(
        Button Box("Fermer",
        nw << Close Window;
       Stop();
The window is closed but my script runs ...
Where is my error ?
Thanks for your help !
ms
Super User (Alumni) ms
Re: [Jsl] How can i stop a script with a button ?
I think Stop() needs to be in the main script. Within a button box, Stop() will just terminate execution of the button script.
Try something like this:
stop_flag = 0;
  V List Box(
  Button Box( "Fermer",
  nw << Close Window;
  stop_flag++;
For( i = 1, i <= 100, i++,
  If( stop_flag,
  Print("Stopped");Stop(),
  Print( "still running" );
  Wait( 0.5 );
ms
stop_flag = 0;
  V List Box(
  nw << Close Window;
  stop_flag++;
  If( stop_flag,
  Wait( 0.5 );
antoinesofradir
Good Job ! it works !
Thank you very much !
MS number one !
gwenicat
Finally! This worked for me as well. I was going slightly demented...
I can't believe it has to be so convoluted...
hogi
Level XIII
@ms wrote:
... Within a button box, Stop() will just terminate execution of the button script.
right!
important to know:
it's not due to the non-modal window, it's due to the limited influence of stop() on the main script.
I just wondered why this script doesn't manage to stop the script before x=5 is executed ...
[in the real script there are additional buttons which will not stop the code]
x=1;
New Window( "Phoenix Viewer",
			<<Type( "Modal Dialog" ),
				Button Box ("OK", Print("OK");stop();  Print("stopped before"))
//stop();
x=5;
so, even for modal windows, one has to a dummy variable to transfer the info to the main script and stop there.
x=1;
stop_flag=0;
				Button Box ("OK", Print("OK");stop_flag++;stop();  Print("stopped before"))
if(stop_flag, stop());
x=5;
