Titanescu
Sheet result of fit parametric survival: how to know if a parameter is protective or deleterious?
Dear Community
I have performed a fit parametric survival analysis in a cohort of patients.
I’m able to identify in the sheet results that several characteristics are statistically associated with the survival.
However, I’m not able to identify whether these characteristics are protective or deleterious.
May you please indicate me how to find this information in the sheet result?
Thank you very much
With my best regards
Alain
Re: Sheet result of fit parametric survival: how to know if a parameter is protective or deleterious?
I suggest that you click the red triangle at the top of the platform and select one of the two profilers. You can profiler the probability (distribution) or the time (quantile) versus the linear predictor. The interactive profiler should allow you to determine in which way each factor affects survival.
Titanescu
Thank you very much!
Best regards
