tgardner4
Set a web proxy for New Http Request
I am trying to access a web API using the New Http Request and route the calls via a web proxy.  JMP support tells me that proxy settings are set at the OS level or the Environment Variable leves.  But my company does not allow changes to the OS or to the environment variables on our issued laptops.  Is anyone aware of a workaround that can force New Http Request to route through a proxy serve that I set for each call?
-Tim
3 ACCEPTED SOLUTIONS
Re: Set a web proxy for New Http Request
This is available in JMP 15.
It's in the Internet Options
OK.
What you are looking for is Proxy User in the Scripting Index.
That should get you what you need.
12 REPLIES 12
Do you mean proxy or vpn? They are different things.
If you mean vpn, then there's nothing HTTP Request can do.
If you mean proxy, then for JMP 14 (and 14.2) environment variables (most networks are set up with auto configure options) is your only option.
BTW... internet open would require a proxy, too. That is, this:
Open(
"https://en.wikipedia.org/wiki/ISO_4217",
HTML Table( 7, Column Names( 1 ), Data Starts( 2 ) )
shouldn't work either
Thanks,
Bryan.
tgardner4
Thanks for the reply Brian.  My need is for web proxy support, not VPN.  The target users here are not allowed to set environment variables.  So I solved the issue by piping the https request to curl via JMP's Run Program function and then reading back the results into JMP.  Curl supports https over web proxy with the -x option.
It's not urgent, but maybe in a future release if JMP it can support an option akin to -x in curl.
If anyone reading this is interested in the curl-based solution, just post a note here and I am happy to clean-up and share the code.
Tim
We'll look into it for JMP 15.  Do you want to add it as a Wish List item?
Thanks for the feedback.
-Bryan
ih
Super User (Alumni) ih
Hi @bryan_boone, do you know how to use this new option added to JMP 15?  I can't seem to find it in the documentation.
ih
Aah, I was looking for a way to do this per call.  Thank you.
Proxy Settings.jpgProxy Settings.jpgYou can do that, too
It's in the Scripting Index.
However most networks are "auto configured" these days. I there some other context?
-Bryan
ih
I am trying to pass different credentials to a proxy server in different parts of a script, while passing a different credentials entirely to the destination site.  I don't see anything in the scripting index or help files related to this, am I missing something?
