Felixxx
Second Y-Axis with different scaling
Hello everybody,
I'm quite new to JMP and have a question regarding plotting your data. Assume you measure a variable that can have different units (e.g. wavelength and energy). I would like to plot the data with one scaling on the left y-axis and the other on the right. I tried inserting a "Formula"-column in the graph builder and move it to the right axis. But that doesn't really do the job, because the axes aren't linked that way.
Thanks for your help!
Re: Second Y-Axis with different scaling
Here is an example where the left and right axes are linked in Graph Builder  All that is needed is to add a simple script to Graph Builder which checks for changes either the left or right axes and then resets the linked axes.
// Create Sample Table
dt = New Table( "Linked",
	Add Rows( 100 ),
	New Column( "Fahrenheit",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values(
			[95, 30, 103, 76, -36, 18, -13, 52, 122, 84, -13, 97, 10, -21, 37, 86,
			102, 10, 38, 56, 81, 91, 21, -13, 47, 34, -22, 28, 41, 88, 58, -8, 22,
			119, 48, 37, 16, -18, 79, 51, 46, 1, 37, 13, -25, 45, 62, 125, 1, 26, 63,
			49, -22, 121, 4, 113, 104, 57, 1, -30, 46, -7, 92, 101, 29, 79, 33, 108,
			11, 60, 21, -35, -33, 39, 80, 8, -29, 113, 130, 41, 76, 60, 108, -17, 43,
			-37, 127, 119, 37, -5, 13, 90, 13, -40, 94, 49, 28, -14, 115, 58]
	New Column( "Celsius",
		Numeric,
		"Continuous",
		Formula( (5 * (:Fahrenheit - 32)) / 9 )
	New Column( "X",
		Numeric,
		"Continuous",
		Set Values(
			[66, 89, 6, 85, 41, 42, 54, 10, 47, 43, 78, 35, 12, 92, 87, 57, 89, 12,
			42, 27, 21, 82, 21, 16, 45, 100, 49, 97, 37, 95, 100, 72, 23, 57, 25, 37,
			1, 32, 53, 48, 35, 43, 61, 52, 34, 65, 93, 78, 34, 84, 55, 47, 76, 22,
			10, 1, 57, 47, 34, 11, 97, 20, 4, 15, 37, 85, 99, 26, 26, 38, 20, 31, 66,
			79, 79, 49, 59, 97, 87, 55, 76, 96, 47, 79, 68, 33, 24, 38, 8, 75, 19,
			70, 48, 43, 95, 74, 1, 51, 85, 23]
// Run Graph Builder
gb = Graph Builder(
	Size( 528, 454 ),
	Variables( X( :X ), Y( :Fahrenheit ), Y( :Celsius, Position( 1 ), Side( "Right" ) ) ),
	Elements(
		Points( X, Y( 1 ), Legend( 14 ) ),
		Smoother( X, Y( 1 ), Legend( 15 ) ),
		Points( X, Y( 2 ), Legend( 16 ) ),
		Smoother( X, Y( 2 ), Legend( 17 ) )
gbr = gb << report;
//Initialize the critical axis values
fmax = gbr[axisbox( 2 )] << get max;
fmin = gbr[axisbox( 2 )] << get min;
cmax = gbr[axisbox( 3 )] << get max;
cmin = gbr[axisbox( 3 )] << get min;
fmaxh = fmax;
fminh = fmin;
cmaxh = cmax;
cminh = cmin;
// Check for change and if found, reset alternate axis
gbr[framebox( 1 )] << add graphics script(
	If( cmax != cmaxh | cmin != cminh,
		gbr[axisbox( 2 )] << max( (9 * cmax) / 5 + 32 );
		gbr[axisbox( 2 )] << min( (9 * cmin) / 5 + 32 );
	If( fmax != fmaxh | fmin != fminh,
		gbr[axisbox( 3 )] << max( (5 * (fmax - 32)) / 9 );
		gbr[axisbox( 3 )] << min( (5 * (fmin - 32)) / 9 );
	fmaxh = fmax;
	fminh = fmin;
	cmaxh = cmax;
	cminh = cmin;
Felixxx
Hello thank you very much for your solution. In general it works, there is only one bug I'm facing: when changing the scale using the mouse key, the axis labels start to flicker. Do you have an idea where this may come from?
I suggest you unselected your "hardware acceleration" for your graphics
