rummeln
Script to save prediction formula of PLS
I'm using a script to run PLS on my data, but I'm having a hard time getting it to save the prediction formula & values into a column in the data sheet.  Is this possible?  Here's what I'm using so far:
P = Partial Least Squares(
	Y( :Viability ),
	X( :Name( "976" ), :Name( "778" ), :Name( "973" ), ),
	Validation Method( None, Initial Number of Factors( 15 ) ),
	Fit( Method( NIPALS ), Number of Factors( 15 ) ),
P << prediction formula;
Thanks
Re: Script to save prediction formula of PLS
Here is the example from the Scripting Index that shows how to Save Prediction Formula
And here is an example using a slight modification to your code, and using the Semiconductor Capability sample data table
dt =
// Open Data Table: semiconductor capability.jmp
// → Data Table( "semiconductor capability" )
Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
	Y( :PNP1 ),
	X( :Name( "NPN1" ), :Name( "NPN2" ), :Name( "NPN3" ), ),
P << obj << (Fit[1] << Save Prediction Formula);
dt =
	Y( :PNP1 ),
rummeln
Worked like a charm, thanks Jim!
hogi
Level XIII
Is there a function to get the prediction formula from a fit as JSL code - without saving it to a column or using a Formula Depot?
Something more robust than
myFit = dt << Fit Model( Y( :height ), Effects( :age, :sex ), Run() );
FormulaExpr=Arg(Arg(myFit << Get Prediction Formula,3))
