psundar6
How do I perform bitwise xor operations between columns with 44-bit binary data?
I want to perform bitwise xor operations between two columns and output the result in the 3rd column. Please note that the values are 44 bits long in both columns.
Please assume as an example the values are 1s on one column and 0s on the other, 44 bits long. Can you explain how I can achieve this with a formula or a jsl script?
Craige_Hales
Re: How do I perform bitwise xor operations between columns with 44-bit binary data?
Extending Jim's approach of using add for XOR, and using some matrix functions to remove the loops...and an ASCII table.
These are untested, make sure they do what you expect.
char_xor = Function( {a, b}, {aa, bb},
    aa = Blob To Matrix( Char To Blob( a ), "int", 1, "little" ); // string to matrix...
    bb = Blob To Matrix( Char To Blob( b ), "int", 1, "little" ); // "0" -> 48, "1" -> 49
    cc = Mod( aa + bb, 2 ); // XOR, 48+48->0, 48+49->1, 49+49->0
    Blob To Char( Matrix To Blob( cc + 48, "int", 1, "little" ) ); // 0->48, 1->49
char_or = Function( {a, b}, {aa, bb},
    cc = aa + bb != 96; // OR, 96 is "0"+"0" == 48+48
char_and = Function( {a, b}, {aa, bb},
    cc = Mod( aa, 2 ) :* Mod( bb, 2 ); // AND, :* is element-wise. multiply 0*0, 1*0, 0*1, 1*1
char_not = Function( {a},
    Substitute( a, "0", "*", "1", "0", "*", "1" ); // NOT
// tests
Show( char_xor( "0011", "0101" ) == "0110",
      char_or( "0011", "0101" ) == "0111",
      char_and( "0011", "0101" ) == "0001",
      char_not( "01" ) == "10" );
p = "00110000011111";
q = "01010101011100";
Show( p, q, char_not( char_and( p, q ) ) == char_or( char_not( p ), char_not( q ) ) ); // De Morgan's Theorem
You might want error checks for bad characters like "010130101".
Wow. Substitute did not work the way I thought it would.
Craige
Here is one way to handle the problem
For( i = 1, i <= 1, i = i + 15,
	loops = Ceiling( Length( :A ) / 15 );
	val = "";
	For( i = 1, i <= Length( :A ), i = i + 15,
		Asub = Substr( :A, i, 15 );
		absLength = Length( Asub );
		zeros = Repeat( "0", absLength );
		Bsub = Substr( :B, i, 15 );
		Csub = Sum( Num( Asub ), Num( Bsub ) );
		Csub = Format( Csub, "Fixed Dec", 15, 0 );
		If( Length( Csub ) != absLength,
			Csub = Substr( zeros, 1, absLength - Length( Csub ) ) || Csub
		val = val || Csub;
	val = Substitute( val, "2", "0" );
Craige_Hales
// tests
Craige
