thebilly31
Save as CSV File - unclear instructions
I am trying to save a subset of a table which is in sav format into a csv file. Under this link I got clear instructions. However, my JMP14 does not have the option to select a type list to save in.
What can I do?
Jeff_Perkinson
Re: Save as CSV File - unclear instructions
Choose Text and on the subsequent dialog set the End of Field delimiter to "Comma". Make sure that the "Hide Extension" checkbox in the lower right is off and you can change the extension from ".dat" to ".csv".
-Jeff
when you select
     File==>Save As
Do you have a drop down arrow like in the image below
thebilly31
No I don't. I am using JMP14 on a Mac so I guess it is different from Windows, but still in other applications I have such a field where I can save as something.
Jeff_Perkinson
If you're using a Mac you should choose File->Export instead of File->Save As...
-Jeff
thebilly31
Thank you. That is better than no file. Is there a way to export to csv?
Jeff_Perkinson
-Jeff
