vishwasanj
Run .jsl without opening any window
Hi All,
Is it possible to run .jsl without opening any windows or data tables in JMP?
I am trying to run everything in background if possible.
Thanks.
uday_guntupalli
Level VIII
Re: Run .jsl without opening any window
@vishwasanj :
       You can keep the data tables "invisible" or "private" where they dont pop up .
        Would that suffice ?
Best
Uday
vishwasanj
Thank you Uday. That's a good idea. Is there a good documentation/post to understand where all I could use invisible or private? I don't want to miss anywhere in my script. Thank you.
uday_guntupalli
Level VIII
@vishwasanj :
  So , two ways to set data tables/ windows to show / disappear are :
1. When you create them
2. When you have a handle / reference to the object .
For case (1)
dt1 = Open( "$SAMPLE_DATA/Big Class.jmp","Invisible" );
dt2 = Open("$SAMPLE_DATA/Air Traffic.jmp","Private") ;
For Case(2)
dt1 = Open( "$SAMPLE_DATA/Big Class.jmp");
dt1 << Show Window(0);
Setting a window to private makes it hidden even in the list of windows of JMP - so this is more closer to your initial need. "Private" can also speed up your script .  Hope this addresses you need .
You can apply the Show Window to a window as well.
Best
Uday
