ngodfrey
Community Trekker
Row Legend Shows Non-Existent Negative Values
I am working with the "Variability Chart" platform and adding a "Row Legend". I am using a "Number of Days Passed" column to indicate color. I am also selecting "Continuous".
However, I am getting a -5 Point showing up in the continuous legend even though none of the points in the column are below 0 days past.
Is there a way to eliminate the -10 from being displayed in JMP?
I want to show a starting value of 0 not -10. It doesn't make sense to have negative days past in this example and makes it appear like the data is incorrect.
I can uncheck the 'continuous' option, but there are a large number of intervals, so I would rather not. The legend becomes quite large.
Thank you,
Nate
Re: Row Legend Shows Non-Existent Negative Values
would it be possible for you to save the Variability Chart script to the data table, and then to attach the table to the discussion?  At least to myself, there isn't enough information/details to figure out what the issue is
ngodfrey
Community Trekker
Thanks for the advice, I posted a picture and an example data table showing what I am referring to. Really, I want a way to set what the starting value is for a continuous legend.
The issue is with JMP assigning values to the color gradient.  The scale it comes up with goes beyond the actual range of your data.  If you change the modeling type to ordinal for the Days Passed, you will get the legend you want
ngodfrey
Community Trekker
Did I do something incorrectly?
I switched the modeling type to "Ordinal" (hence the green bars), but the legend still shows the -10 point.
Thank you,
Nate
You will need to rerun the analysis.
