OnlyPractice
Repeating Normal Clustering with varying cluster number
Hi. all
I am new to JMP especially working with JSL, and I have been trying to make script that automate Normal Clustering with varing cluster number
using cond
itional function such as for() however, normal mixture doesn't understand the variables and
only takes numbers. so I hope i can find ways to put variables into number arguments, or
any other alternatives.
my script is just like this:
nw = new window("clustering",
for(i=1, i<5, i++,
Normal Mixtures(
Y(:column names1, :column names2, :column names3  ),
{Mixtures Tolerance( 0.00000001 ), Mixtures MaxIter( 300 ),
Mixtures N Starts( 30 ), Outlier Cluster( 0 ), Diagonal Variance( 0 ),
Number of Clusters( i ), Go})));
Re: Repeating Normal Clustering with varying cluster number
If you write out the value of "r"
show( r );
It returns the value
r = [2];
The message
     << get rows where()
returns a matrix of values, not a scalar value. If you wrote out the value of the first element in the matrix called "r",
Show( r[1] );
It would  display
r[1] = 2;
So the solution to your issue is to reference the 1st element of the variable "r"
dt << Normal Mixtures(
	Y( :Sepal length, :Sepal width, :Petal length ),
	{Mixtures Tolerance( 0.00000001 ), Mixtures MaxIter( 300 ), Mixtures N Starts( 30 ), Outlier Cluster( 0 ),
	Diagonal Variance( 0 ), Number of Clusters( r[1] ), go}
I am not really sure what you are doing with the Column Names1, 2 and 3.  I have guessed of their usage below.  Here is an example script that works as I think you want.
dt = Open( "$SAMPLE_DATA/Iris.jmp" );
nw = New Window( "clustering", vlb = V List Box() );
column names1 = "Sepal length";
column names2 = "Sepal width";
column names3 = "Petal length";
For( i = 1, i <= 4, i++,
	obj = dt << Normal Mixtures(
		Y(
			Column( column names1 ),
			Column( column names2 ),
			Column( column names3 )
	obj << Go;
	vlb << append( Report( obj ) );
	obj << close window;
OnlyPractice
Hi dear txnelson
Thank you for reply. It really helps solving some of my problems. but still some problems aren't solved.
To be more detail, My Intention was to make script that choose best normal clustering numbers out of (1 to n)(integer larger than 1 that users insert in add-ins)clusters and show only that optimum normal cluster report only.
With the help of txnelson's answer I was able to make script that extract best normal clustering numbers(in other words, smallest BIC). But I faced another huddle with making normal cluster with only extracted best clustering number. And my script was as follows;
j=7;
nw2 = New Window( "clustering", vlb = V List Box() );
for(i=1, i<=j, i++,
		Y(
			:Sepal length,
			:Sepal width,
			:Petal length
Number of Clusters( i )}
	obj << Go;
	obj << close window();
    nw2[tablebox(1)] << make combined data table;
	pr = current data table();
	mn = Col Minimum(:BIC);
	r = pr << get rows where(:BIC == mn);
dt << Normal Mixtures(Y(
			:Sepal length,
			:Sepal width,
			:Petal length
Number of Clusters( r ),go}
Even though i saved specific cluster number to 'r' variable, the 'normal mixture' doesn't realized that variable value. It seems to me that 'Normal Mixture' take the variable as number only if used with 'for' functions.
Hope there is any solutions or alternatives to this problems.
OnlyPractice
Hi dear txnelson
j=7;
for(i=1, i<=j, i++,
Y(
:Sepal length,
:Sepal width,
:Petal length
obj << Go;
:Sepal length,
:Sepal width,
:Petal length
show( r );
r = [2];
The message
     << get rows where()
Show( r[1] );
It would  display
r[1] = 2;
OnlyPractice
Thanks you so much!! It really helped.
I wasn't cautious to distinguish between scalar values and vectors of specific functions.
