PeterD
Reordering ordinal values
Hi
I have a dataset that was pulled from Survey Monkey and there are a variety of answers to questions that are ordinal--and not well ordered.
For instance Purchase Intent has five values--JMP defaults to order alphabetically (which makes no sense of course)
Definitely would
Definitely would not
Might or might not
Probably would
Probably would not
 -- how can I reorder this more logically so that when I show the analytic results with values in the logical order?
Definitely would  |  Probably would  |  Might or might not | Probably would not | Definitely would not
Peter
Re: Reordering ordinal values
Go to the column header.  Right Click and select "Value Order".  It will let you set the order of the values.
PeterD
Thanks--you have really helped out this newbie
Let me help you out some more.  The Discovering JMP Document, under the Help pull down menu gives one a real "leg up" when learning JMP.  I strongly suggest you take the time to read through it!  It will make you a far more efficient JMP user in the shortest time possible.
PeterD
Thanks!
