justvince
Remove Quotes : Script to make column Formula
I am in the beginnings of making a script to find the delta between two measurements for many columns.
I am having difficulty making column formulas when the column name has a dash....
The parse command to remove quotes changes the dash to a minus operand which then messes with what I am trying to accomplish.
Error log:
Unexpected "_92MHz_test_data". Perhaps there is a missing ";" or ",".
Here is the script (which works if the column(s) do not have an operand in the name.
E.g.,
dt = Current Data Table();
Col_Name = "diff";  // column(5) - Column(300)
Col_Name1_char = Char( Column Name( 5 ) ); // "bin of DWK112079-01_92MHz_test_data""
Col_Name2_char = Char( Column Name( 300 ) );// "bin of  DWK112079-01_90MHz_test_data""
Col1_Name = (Concat( ":", (Col_Name1_char) )); //":bin of DWK112079-01_92MHz_test_data";
Col2_Name = ((Concat( ":", Col_Name2_char ))); // ":bin of DWK112079-01_90MHz_test_data";
Formula_I = ((Concat( col1_Name, " - ", Col2_Name )));  //Make the formula expression
a = Expr(
    New Column( X, formula( Z ) )
); // New column with name Diff
b = Substitute( Name Expr( a ), Expr( X ), Col_Name, Expr( Z ), Parse( Formula_I ) );  // This has error when Colnames has "-" in the name
Eval( b );
//Note:
Show( Forumula_I, Parse( Formula_I ) );
//Note :  Formula_I = ":bin of DWK112079-01_92MHz_test_data - :bin of DWK112079-01_new_updated_test_data";
//Note    Parse(formula_I) = :bin of DWK112079 - 1;  This is not what I want
Re: Remove Quotes : Script to make column Formula
The "-" in the middle of a column name is being interpreted by JMP as a subtraction.  Therefore, you need to indicate to JMP that the whole term is a column name.  The easiest way to do this is to use the naming structure of
     ":column name"n
The below is a rework of your script with the changes made
names default to here(1);
Col1_Name = (Concat( ":\!"", (Col_Name1_char), "\!"n" )); //":bin of DWK112079-01_92MHz_test_data";
Col2_Name = ((Concat( ":\!"", Col_Name2_char  , "\!"n" ))); // ":bin of DWK112079-01_90MHz_test_data";
a = Expr(
Eval( b );
//Note:
     ":column name"n
a = Expr(
Eval( b );
//Note:
justvince
I would have never been able to figure this out.   Thanks so much, works perfectly!
