psundar6
Remove Duplicate rows using Timestamp
I have a sample data table attached wherein I am looking to remove duplicate rows within the data set using the TimeStamp,Tool columns.
Criteria for duplication:
Timestamp that are within 6mins on the same tool are considered as duplicates and those rows have to be removed.
Can someone help how this can be achieved in JSL?
@txnelson
Re: Remove Duplicate rows using Timestamp
I believe this will give you an example on how to proceed with your issue
// Loop through the data table deleting all duplicate rows
i = 1;
While( i <= N Rows( dt ),
	// Find the upper and lower bounds to match on
	lower = :timeStamp[i] - In Minutes( 6 );
	upper = :timeStamp[i] + In Minutes( 6 );
	// Find the rows that match
	theRows = dt << get rows where( :timeStamp > lower & :timeStamp < upper );
	// Remove the current row from the list.  We do not want to delete it
	Try( theRows[1] = [] );
	// Delete the remaining rows
	Try( dt << delete rows( theRows ) );
	// Increment the row to work on
	i++;
ron_horne
Hi @psundar6 ,
@txnelson provides a very good solution.
An alternative approach using table sort and column formula could be done interactively or by scripting as follows:
dt = current data table();
dt << Sort(
	By( :TimeStamp, :Tool ),
	Replace Table,
	Order( Ascending, Ascending )
dt << New Column( "to delete",
	Numeric,
	"Ordinal",
	Format( "Best", 12 ),
	Formula( If( :Tool == Lag( :Tool, 1 ) & Date Difference( Lag( :TimeStamp, 1 ), :TimeStamp, "Minute" ) < 6, 1, 0 ), eval formula )
dt:to delete << suppress eval(true);
dt<< delete rows (dt<< get rows where (:to delete == 1));
let us know if it works for you.
i = 1;
	i++;
psundar6
This works, Thank you!
ron_horne
Hi @psundar6 ,
dt << Sort(
	Replace Table,
	Numeric,
	"Ordinal",
psundar6
Hello Ron,
I tried your solution and I see an issue with the result.
I have attached the result from running your code. It seems like it is not catching a couple of duplicate entries for some reason.
Thanks.
ron_horne
Thanks @psundar6 for letting me know. there was a typo now I have edited the script..
