uProf
How to Get Consistent Font Size on Y axis scale
Hi -
I am using Graph Builder to plot the following using JSL. Given the data is dynamic, I am not hard coding any axis/scale settings. Percentage value is set to 3 digits after decimal point though.
Is there a way to fix the font size in the example below? I would like to have same font size on Y axis scale.
Thanks!
ron_horne
Re: How to Get Consistent Font Size on Y axis scale
Hi @uProf
try a right click on the axis >> axis settings
there you have an option to de-select - Automatic font size.
let us know if it works.
ron_horne
Hi @uProf
