HHanna232
Non normal data in fit model
Hi, I have a data-set of continuous data with a mixture of variables being normally and non normally distributed. For the normally distributed data i have built a model in fit model with one fixed variable and a covariate. For the non-normal data I would like to use a Kruskal-wallis with a covariate? Is this possible to do?
Thanks!
ron_horne
Re: Non normal data in fit model
Hi @HHanna232 ,
These tests are available under the fit y by x platform. There you can ask for them under the red triangle.
Yet, you may need to create a new categorical variable to include all the combinations of groups into one single factor for X.
