BookmarkSubscribe
pchavarkar
Referencing Text Boxes in Object
I am trying to change the orientation of a text box in object using the following script
ProbeMap[TextBox(40)]<<Rotate text("Left");
However I get the following error.
Cannot subscript Display Box{3825} in access or evaluation of 'Subscript' , ProbeMap[/*###*/Text Box( 40 )]
In the following script, error marked by /*###*/
ProbeMap[/*###*/Text Box( 40 )] << Rotate text( "Left" )
Tree structure of ProbeMap has TextBox(40), so I don't understand the reason for getting the error
Thanks
7 REPLIES 7
David_Burnham
Re: Referencing Text Boxes in Object
Is ProbeMap the object or the report window associated with the object?  Perhaps you need something like:
rep = ProbeMap << Report;
rep[TextBox(40)]<<Rotate text("Left")
-Dave
I am making the assumption that ProbeMap is a handle pointing to a display window.  To make your code work, you need to find the root of the window.  Here is some code that will illustrate how to do this
probemap = New Window( "test",
	Outline Box( "this is a test",
	Text Box( "the text box" ) )
rootParent = probemap << top parent
rootParent[Text Box( 1 )] << Rotate text( "Left" );
David_Burnham
Give or take a semicolon this is a better suggestion than mine, given the error message.
-Dave
Here is the code with the missing semicolon added in
rootParent = probemap << top parent;
Dave, thanks for the catch
pchavarkar
Thanks everyone,
The code works, however one has to be careful about using the correct
object index.
See Example below
To change orientation of "DIE_COL" text (referenced as TextEditBox(22) in
the tree structure) I had to use the following code.
rep= ProbeMap << Top Parent;
rep[TextEditBox(11)]<
instead of
rep[TextEditBox(22)]<
In summary, the object index required to manipulate the object is different
from the object index as seen in the tree structure.
[image: Inline image 1]
When referencing an offset from a point in any display box, the reference number will change depending upon the anchor point one is offsetting from.  Therefore, I typically try to start my offsets from a Outline Box() close to the object I am going to be going after.
I consider this approach a 'best practice' that avoids (or at least minimizes) the problems with subscripts for display box objects in the display tree.
