Susanth
Community Member
RSM model ; Face centered CCD
Hi, I am trying to create a face centered CCD design with four factors and three levels each. The design I am trying to create needs to be composed of 6 axial points, six central points and the mid point between high and low levels. I am finding difficulty in creating the mid axial point. Which script to type for this model?
Re: RSM model ; Face centered CCD
You do not need to script this task. It is part of the interactive user interface:
  1. Select DOE > Classical > Response Surface Design.
  2. Define your responses and factors.
  3. Click Continue.
  4. Select the 30-run CCD with 6 center points and click Continue.
  5. Select On Face and click Make Table.
See Help > Books > Design of Experiments Guide and chapter about Response Surface Designs for more details about this design platform.
