Our World Statistics Day conversations have been a great reminder of how much statistics can inform our lives. Do you have an example of how statistics has made a difference in your life? Share your story with the Community!
anne_sa
Question about response surface analysis
I have a question about the analysis of a response surface design.
In my design I have 4 factors and 3 responses.
I launch the fit model platform (which is already completed by JMP) then from the Effect Summary I remove the non significant effects. After that I look at the Prediction Profiler and I maximize the desirability regarding my 3 responses.
However some effects are not significant for all responses. Thus I wonder if I should rather run an analysis for each response separately, keep only the significant effects in each model (so I may have 3 different models), save the prediction formula and finally launch the Profiler Platform from the Graph menu to maximize desirability.
What do you think about that?
Thanks in advance for your advices!
ian_jmp
Re: Question about response surface analysis
Having a different model for each response strikes me as very reasonable - After all, there is no reason why, on physical, technological or mecahnistic grounds the pattern of response should be the same. This also brings up the related issue of if, and then how, a model should be refined by dropping terms. Statistical considerations aside, such choices should be influenced by what the rersulting model will actually be used for.
ian_jmp
anne_sa
Thanks for your answer Ian I will keep on exploring my data set!
I concur with Ian. In fact, we generally recommend this practice in training whenever there is more than one response. Taking this idea a step further, it means that you can model each response with the best possible model: linear model, neural network, and so on and then combine them for optimization. Also, you might have models to be included in the optimization that came from experiments or theory from the past. This set up is very flexible.
anne_sa
 Thanks for the precisions Mark!
Article Labels
