Problems with parallel graphs: Continuity and similar scale
Created:
Aug 24, 2021 07:10 AM
| Last Modified: Jun 11, 2023 4:17 AM(3317 views)
Hi mates,
Working with parallel graphs, I have got 2 problems and would be appreciated if anyone can help me resolve it.
1- Continuity: Say you have 6 series on your X-axis, but one of your data sets is missing series 4, then the connection between 3 and 5 will be missed. Is there any way to make the graph continues and connects the series just neglecting the missing points?
2- Scale: If the number of series increases in the parallel plot, each of the verticals will have its own scale which is not editable. Is there a way to make the same scale for all of them?
On your first issue, the only think I can suggest is that you could calculate a value for the missing cells. Setting the value to zero....iff appropriate, or interpolating the value the cell would have if the line was drawn from the previous non missing value to the first non missing value.
On the second issue, there is a checkbox on the initial dialog that standardizes the scales.
Re: Problems with parallel graphs: Continuity and similar scale
Created:
Oct 16, 2022 08:51 AM
| Last Modified: Oct 16, 2022 7:09 AM(3219 views)
| Posted in reply to message from Hamid 08-25-2021
For the parallel Plot in GraphBuilder, is there a setting to use a common Y scale for all parameters? For the plot below, if the grades keep a constant position along the Y axis, it will be much easier ...
