How to change the order of sequence stacking in a stacked bar chart?
Created:
Oct 16, 2022 09:54 AM
| Last Modified: Jun 11, 2023 4:28 AM(8696 views)
In stacked bar chart, how to change the order of legend stacking in a stacked bar chart,I want to freely adjust the display position of each legend in the stacked bar chart.
You can use the Value Ordering column property in the data table to change the order of the stacked elements. All bars will use the order from the column property.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '556701' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '556701') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '556701') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
