Françoise
Problem with Excel
hi,
someone has made for me  a database with Excel.xlsb.
When I import it, the database opens with Excel.
is there a solution to import it with Jmp?
best regards
11 REPLIES 11
David_Burnham
Re: Problem with Excel
I did a quick search and found these: save data table as excel xlsb and How to open .xlsb file?
-Dave
Françoise
thanks David for your answer.
I 've seen the message of Tom Abramov (2019).
I hoped that someone of the R&D had found a solution because *.xlsb is interesting to reduce the size of the excel files.
best regards
Does the File > Database > Open Table approach work with workbooks saved using the binary XLSB format?
David_Burnham
Could be a good route - The ODBC driver for Excel files supports XLSB formats.
-Dave
Françoise
I haven't  connection in the database Operations
My Jmp is 64 but my Excel is 32 and I'm not used to use ODBC.
I tried with the query builder but it could not be executed.
May be someone else can test it to help others members?
stan_koprowski
Hi @Françoise
If you match the bitness of your ODBC driver to that of JMP it should work.
I was able to import the VA Lung Cancer data provided in the sample data using JMP Query Builder.
Import .xlsb file using JMP Query BuilderImport .xlsb file using JMP Query Builder
cheers,
Stan
Françoise
dear Stan,
I will try it
Françoise
Stan,
no success with your solution.
can you give me the beginning of this script?
best regards
mzwald
If you are opening Excel files with JMP, make sure the "Use Default Program to Open" box is unchecked when selecting from the File Open dialog window. That way the file opens in JMP rather than the default program (Excel).
