Gabriel
Probability density function_pdf
Good afternoon all,
I am looking to make a probability density function graph, how best can I do it using jump graph builder? How can the density (y) axis be scaled?
some like what I have attached in the image.
Thank you.
Gabriel Mulero
ZF
ZF
Re: Probability density function_pdf
Please see attached, using graph builder to plot probability density function.
What you need to use, is the Distribution Platform.
Select the column(s) you want, then under the red triangle, select
     Display Options=>Horizontal
     Histogram Options=>Density Axis
     Histogram Options=>Shadowgram
ZF
ZF
