Raquel
Display only certain data points in Row Legend
I have a data table where I create a subset data table that only contains the data that I want to appear in my Control Chart. For some reason, the subset data appears correctly in the chart but the Row Legend still contains all of the data values from the original data table as well. How can I make it so that the Row Legend only displays data from the subset data table (the values noted in the script as "ColumnP")?
dt=Data Table("SPC Chart")<< Clear Column Selection;
ColumnP ={5, 11, 13, 19, 27};
dt<<select where(contains(ColumnP, :Name("Column P Data")));
dt<< Subset(
output table name( "Subset Column P" ));//, invisible);
dt2=Data Table("Subset Column P");
dt2<< Clear Row States;
dt2<<Current Data Table() << Color by Column(
	Name( "Column P Data" ),
	Color( 1 ),
	Color Theme( "JMP Default" ),
	Marker( 0 ),
	Marker Theme( "" ),
	Continuous Scale( 1 ),
	Reverse Scale( 0 ),
	Excluded Rows( 0 )
dt2<<Control Chart(
	Sample Label( :Date),
	Group Size( 1 ),
	KSigma( 3 ),
	Chart Col( :Name( "Column E Data" ), Individual Measurement, Moving Range ),
	Where( :StepNumber == 1 & :Material == "Substance"),
		Dispatch(
			{"Individual Measurement of Column E Data"},
			"IR Chart of IM",
			FrameBox,
			{Frame Size( 800, 200 )}
		Dispatch(
			"IR Chart of IM",
			FrameBox,
			{Frame Size( 800, 200 ), Row Legend(Name( "Column P Data" ),
	Color( 1 ),
	Marker( 0 ),
	Marker Theme( "" ),
	Reverse Scale( 0 ),
	Excluded Rows( 0 ))}
		Dispatch(
			{"Moving Range of Column E Data"},
			"IR Chart of MR",
			FrameBox,
		Dispatch(
			"IR Chart of MR",
			FrameBox,
Raquel
Re: Display only certain data points in Row Legend
I'm using JMP 15. I just figured out my problem. The Row Legend was set on continuous scale so I thought it contained all of the data values from the original data table (which it did but it was just a scale based on the minimum and maximum data values in the subset data table). I changed Continuous Scale to "0" and now my Row Legend is displaying only the exact values of the data points present in the subset data table.
	Color( 1 ),
	Marker( 0 ),
	Marker Theme( "" ),
	Continuous Scale( 0 ),
	Reverse Scale( 0 ),
 Thanks for looking into this and jogging my scripting memory!
I have not been able to replicate your findings.  What version of JMP are you using?
Raquel
	Color( 1 ),
	Marker( 0 ),
	Marker Theme( "" ),
	Reverse Scale( 0 ),
