Kanstantsin
Pixellation in GraphBuilder titles
Hi everyone,
not sure whether this is a bug or whether i'm doing something wrong, so maybe someone could help.
When i export graphs from GraphBuilder and the "transparency" in Preferences/Reports is "on", i get a very pixellated text:
if I turn it off, it looks fine:
I want to have transparent backgrounds with the normal quality text. Would anyone happen to have a suggestion on how to solve this?
Another note - if i export it to PowerPoint, the text is good and the background is transparent, but export to file (via script) gives the pixellated picture, as in the example.
Best wishes,
Konstantin
Level XIII
Re: Pixellation in GraphBuilder titles
you could check under Preferences/Windows specific the resolution for PNG and JPEG export.
With "300" you will get a much better quality.
I am also a big fan of EMF export. On a Windows system you can even change parts of the plot later in Powerpoint.
To make it work, you have t o enable EMF copy/paste in the preferences.
Disadvantages of EMF:
  • Just works for programs which support EMF (so don't disable the other option if you want to send plots via Teams :).
  • Please also note that depending on the size of the table, the EMF export can take very (!) long.
    On the other hand, the speed for copy/paste can be increased tremendously if EMF is deselected:
Thierry_S
The answer will vary depending on your system (Windows or MacOS) and export method.
For Windows Copy-Paste, you could try Paste Special > Enhanced Metafile to improve the resolution of the exported plots.
  • Copy the plot as usual
  • In the receiving application (Word, PowerPoint), press CTRL + ALT + V
  • Select "Enhanced Metafile" (not the Window Enhanced Metafile)
Let us know if that help.
Best,
TS
Thierry R. Sornasse
Level XIII
Kanstantsin
Thanks for the replies! Gonna go with this one, because this saves a few clicks when inserting individual graphs somewhere!
I'm actually running a jsl loop like this to put a bunch of images into one report (with some custom axis autoscaling and a pptx export as well):
win = New Window( "Window", Outline Box( "Graphs", hb = V List Box() ) );
For( i = 9, i <= N Cols( dt ), i++,
	gb = Graph Builder( Variables( X( :Column1 ), Y( Eval( i ) ), overlay( :Group ) ) );
	hb << Append( Report( gb ) << child );
	hb << append( Page Break Box() );
	gb << Save Picture( "path" || strTitle || ".emf", emf );
	gb << close window;
