mylifemyrule
How to Export Journal to PDF using Script
hi All,
I have combine all the graph in a journal using below method.
But I'm not sure how can I export that Journal to PDF report.
platform << report << Journal();
vc << report << Journal();
dist << report << Journal();
I try this but it doesn't work:-
w = CurrentJournal();
w << Set page setup(
margins( 1, 1, 1, 1 ),
scale( 1 ),
portrait( 1 ),
paper size( "Letter" )
w << save pdf( "$DOCUMENTS\test.pdf" );
Re: How to Export Journal to PDF using Script
What issues are you facing? This does create pdf correctly (using JMP17.0 and Windows 10)
//This message applies to all display box objects
biv = dt << Bivariate(y(:weight), x(:height));
rbiv = biv << journal;
w = Current Journal();
w << Save PDF("$TEMP/jmp_example.pdf");
Open("$TEMP/jmp_example.pdf");
