Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
mgerusdurand
Pie Chart Labels organisation
I try to dig in the community to find my answer but couldn't.
I have a script generating monthly report as a pie chart. I moved the labels on first one to make them readable and copy the position in my script. This is working when using the same data but the répartition of data is not the same over months so labels become overlapping again.
Is there a way to have connecting lines between the pie section and data so they can be spread over the pie while staying visible, without overlapping? I am using JMP 16 to 18.
Thanks for your help
MGD
Re: Pie Chart Labels organisation
Too bad you cannot get rid of the pie chart (most overused and usually bad way to visualize anything). Below is script which might give some idea what you could do, the calculations definitely aren't optimal but they might work (I don't really remember unit circle and trigonometry anymore)
ADJUSTED_LOCATION = 0.8 ; // default is 1
dt = open("$SAMPLE_DATA/Big Class.jmp");
gb = dt << Graph Builder(
	Variables(X(:age), Y(:height)),
	Elements(Pie(X, Y, Legend(2), Summary Statistic("Sum"), Label("Label by Value")))
fb = Report(gb)[FrameBox(1)];
pie = fb << Find Seg("Pie Seg");
{x_origo, y_origo} = pie << Get Origin;
radius = pie << Get Radius;
Summarize(dt, groups = By(:age), sums = Sum(:height)); // we must know summary statistic used in pie chart
r_sections = Reverse((sums / Sum(sums)) * 2 * Pi());
angles = {};
For Each({section, idx}, r_sections,
	angle = (section + Pi()) / 2;
	If(idx > 1,
		angle = angle + Sum(r_sections[1::idx - 1]);
	Insert Into(angles, angle);
label_locations = {};
For Each({angle, idx}, angles,
	i = N Items(angles) - idx;
	xcoord = x_origo + ADJUSTED_LOCATION * Cos(angle);
	ycoord = y_origo + ADJUSTED_LOCATION * Sin(angle);
	location = Eval List({i, xcoord, ycoord});
	Insert Into(label_locations, Eval List({location}));
For Each({location}, label_locations,
	Eval(EvalExpr(
		pie << Set Label Offset(Expr(location));
default
ADJUSTED_LOCATION = 1.1
This could be turned into a function which would be able to add lines to the labels.
Example how lines could be added
ADJUSTED_LOCATION = 1 ; // default is 1
calculate_pie_graph_angles = Function({gb}, {Default Local},
	dt = gb << Get Data Table;
	// Get X and Y columns (doesn't currently support Overlay)
	vars = gb << Get Variables;
	xcol = Empty();
	ycol = Empty();
	For Each({var}, vars,
		role = var["Role"];
		If(role == "X",
			xcol = Arg(var, 1) << get name; // I don't use references
		, role == "Y",
			ycol = Arg(var, 1) << get name; // I don't use references
	// Get summary statistic
	elements = gb << Get Elements(1, 1);
	summary_stat = Try(elements[1]["Summary Statistic"], "Mean"); // We assume Mean is the default one
	// Calculate groups and segments
	// I'm lazy and use Evil Parse here
	stat = Eval Insert("^summary_stat^(Eval(ycol))");
	Eval(EvalExpr(
		dt_summary = dt << Summary(
			Group(Eval(xcol)),
			Expr(Parse(stat)),
			Freq("None"),
			Weight("None"),
			statistics column name format("column"),
			Link to original data table(0),
			invisible
	groups = dt_summary[0, 1]; // 2 is N Rows
	stats = dt_summary[0, 3];
	Close(dt_summary, no save);
	// calculate segments
	r_sections = Reverse((stats / Sum(stats)) * 2 * Pi());
	angles = {};
		If(idx > 1,
	Return(Reverse(angles));
get_segment_locations = Function({pie, angles, radius = 1}, {Default Local},
	pie_radius = pie << Get Radius;
		i = idx - 1;
		xcoord = x_origo + radius * Cos(angle);
		ycoord = y_origo + radius * Sin(angle);
	return(label_locations);
angles = calculate_pie_graph_angles(gb);
offsets1 = get_segment_locations(pie, angles, 1.05);
For Each({location}, offsets,
	Eval(EvalExpr(
offsets2 = get_segment_locations(pie, angles, 0.9);
offsets3 = get_segment_locations(pie, angles, 1.02);
For Each({{start, end}}, Across(offsets2, offsets3),
	Eval(EvalExpr(
		x = start[2] || end[2];
		y = start[3] || end[3];
		fb << Add Graphics Script(
			Line(
				Expr(x), Expr(y)
9 REPLIES 9
I don't know of a way of adding such lines to pie chart easily. You could calculate those lines and add them with a script or perform some calculations and set the offsets by script.
mgerusdurand
Thanks @jthi.
As my data are changing every month and all categories are not always present it is hard for me to code all of this, even the offset mais not be for every month.
As an alternative I can put the labels on sections of pie chart and alternate the distance to the center of the pie to ensure they are not overlapping. Do you know if the option existes or do I need to script that?
Thanks again
MGD
I would most likely use something else than Pie Chart (much easier than start scripting Pie segments, even the documentation in Scripting Index is wrong in most of the cases for that...), but this seems like a nice challenge so I'll try to write some sort of a script for this.
mgerusdurand
Thanks a lot. I can try too but I think you will be much faster than me.
I tried to make my supervisor change her mind for another graphic representation but she wants a pie chart unfortunately , this is not my favourite.
I will write something on the wish list too because it is true that scripting index is not good for this.
Thanks again
MGD
angles = {};
	If(idx > 1,
	Eval(EvalExpr(
default
	xcol = Empty();
	ycol = Empty();
		role = var["Role"];
		If(role == "X",
		, role == "Y",
	Eval(EvalExpr(
			Group(Eval(xcol)),
			Expr(Parse(stat)),
			Freq("None"),
			Weight("None"),
			invisible
	angles = {};
		If(idx > 1,
		i = idx - 1;
	Eval(EvalExpr(
	Eval(EvalExpr(
			Line(
				Expr(x), Expr(y)
mgerusdurand
Wow you were so fast!
Thanks a lot Jarmo this do the job perfectly
MGD
dlehman1
Echoing the other comments, don't use pie charts - I'm more emphatic than others on this point.  But here is a very good presentation illustrating why it is always better to use a bar chart (or similar alternatives) than a pie chart:  https://speakerdeck.com/cherdarchuk/data-looks-better-naked-pie-chart-edition.  I'd view this a chance to educate your supervisor.
mgerusdurand
Hello @dlehman1,
Thanks for the link. I will try to educate them but they have pretty strong feelings for pie chart. I will make the parallel with other visualisation to try to convince them.
MGD
