KellyT
Parsing Datetime with symbols
Dear community:
I am having trouble to find a good solution to parse Datetime examples below by changing the "Format" (under "Column Info"):
2018-01-01 14:44:19.290000+00:00
2018-01-01 13:43:40.090000+00:00
Currently, I have to use Regex to find the pattern after the period and then replace it with blank.  I am hoping that there is an easy option.
Thank you for your help!
Re: Parsing Datetime with symbols
I don't know if this result is quite what you want but it is simple.
I used this formula in another column and left the original alone.
Informat( Substitute( Word( 1, :Date Time String, "+" ), " ", "T" ), "yyy-mm-dd" )
Jeff_Perkinson
Again, my favorite function comes the rescue.  Word(), using "+" as the delimiter can give you the bit before the plus. Then you can use Informat() to convert it to a date value. Informat(), without a second argument, will let JMP figure out the format on it's own if it can.
Read more about these two topics:
If you learn only one Formula Editor function, Word() is the one
Using dates, times, datetimes and durations in JMP
-Jeff
Craige_Hales
Staff (Retired)
The T format is really useful for exchanging date time values, even if it is a bit ugly.
https://en.wikipedia.org/wiki/ISO_8601#Combined_date_and_time_representations
Craige
