PROC MIXED OUTPUT
I am having trouble with my PROC MIXED output in SAS. When I run the programme, the results in the output window are difficult to follow. Instead of all the results fitting into one 'table' the results are all broken up into several smaller tables. I am unable to make any comparisons as a result.
My ANOVA tables are also coming out the same when I run PROC GLM. I've tried all the settings I can think of but can't seem to get anywhere. Can anyone help me please?
PROC MIXED OUTPUT
I think you will be more likely to get a response if you post this in either the procedures or statistics' forums.
