NeF
NeF
P-value Tukey's
Are all p-values in JMP two-tailed? including Tukey's posthoc test?
Thanks,
Ne
Phil_Kay
Re: P-value Tukey's
Are you talking about the All Pairs, Tukey HSD in a oneway analysis using Fit Y by X?
As a quick answer: No, not all p-values in JMP are two-tailed. For example, the simple t-test in the oneway analysis has p values for two- and one-sided tests.
Have a look in the help documentation for the oneway analysis.
Regards,
Phil
NeF
NeF
Re: P-value Tukey's
Yes, I meant Tukey's test from one-way ANOVA. Is it two tailed?
Best,
Ne
Phil_Kay
Re: P-value Tukey's
Yes, it is 2-tailed.
