tom_abramov
Level V
Overlay chart with phases
I would like to build kind of IR Control chart with phases but with user defined limits for each phase instead of control limits calculated by JMP.
I tried it in Graph Builder but I cannot set X axises independent.
Please see screenshot of my trial in Graph Builder.
Thank you.
ian_jmp
Level X
Re: Overlay chart with phases
You can interactively add a graphics script to Control Chart Builder to draw the spec limits. To see an example run the code below.
NamesDefaultToHere(1);
dt << Control Chart Builder(
					Show Control Panel( 0 ),
					Show Limit Summaries( 0 ),
					Show Capability( 0 ),
					Variables( Y( :height ), Phase( :sex ) ),
					Chart(
						Position( 1 ),
						Limits( Sigma( Moving Range ), Show Center Line( 0 ), Show Limits( 0 ) ),
						Add Spec Limits( {LSL( 55 ), USL( 65 )} )
					Chart(
						Position( 2 ),
						Dispatch(
							"Control Chart Builder",
							FrameBox( 2 ),
							{Add Graphics Script(
								2,
								Description( "Spec Limits" ),
								Pen Color( "Red" );
								Line Style( "Dashed" );
				// Spec limits for Females
								H Line( 0, 18, 55 );
								H Line( 0, 18, 65 );
				// Spec limits for Males
								H Line( 19, 40, 57 );
								H Line( 19, 40, 70 );
							), Grid Line Order( 1 ), Reference Line Order( 3 )}
which gives:
With a little work, you could do this programmatically if you have many cases.
You can do this in Control Chart Builder.  See my blog post.  https://community.jmp.com/t5/JMPer-Cable/4-ways-to-use-fixed-baseline-historical-control-limits-in/b...
Take a look at Method #3.
tom_abramov
Level V
Thank you Tonya.
"Get Limits" solves this when I have two limits to show.
I need to show two pairs of limits (for example spec. and control limits) with phases.
Is that possible in Control Chart Builder or Graph Builder?
I tried in Graph Builder but the problem is same X Axes for each phase.
Is it possible to make independent X Axis for each phase?
BG.
Control Chart Builder does not offer capability analysis with a phase variable.  You could do this in the new Process Screening platform.  However, it will not give you the graph you are looking for.  You will get a separate graph for each phase rather than a single graph.
Graph Builder is not my area of expertise.  Perhaps someone else can comment on your question about separate axes.
ian_jmp
Level X
					Chart(
						Position( 1 ),
					Chart(
						Position( 2 ),
						Dispatch(
							FrameBox( 2 ),
								2,
								Pen Color( "Red" );
which gives:
tom_abramov
Level V
Great!
Thank you!
