lala
Level IX
Open an html file with JMP's built-in browser. How do I get the content displayed with JSL?
This removes html structure files quickly.
太阳的微笑
原创 大v专访 2022-09-14 20:30 福建
淘时刻
人划线
Re: Open an html file with JMP's built-in browser. How do I get the content displayed with JSL?
If you already have the .html you can just load it using Load Text File().
lala
Level IX
回复: Open an html file with JMP's built-in browser. How do I get the content displayed with JSL?
Use New HTTP Request with Get method on the URL
request = New HTTP Request(
	URL("https://www.jmp.com/en_fi/home.html"),
	Method("Get")
data = request << send;
You might also have REST API endpoint you could use. If these aren't enough might have to use something like SeleniumBrowser Scripting with Python Selenium
lala
Level IX
This is the only result:
Thanks Experts!
lala
Level IX
Dealing with this type of code with JAVA interactions can be complex.
u="";txt=loadtextfile(u);
  • In the first post, I had to upload this html file
Thanks Experts!
lala
Level IX
Call AutoHotkey with JSL to copy.
