ComplexNerd
Jmp project all open reports
Hello guys,
I started using jmp project recently. I want to write a script which loops through all reports in the project and perform a action and update the report. Any idea on how to go about this kindly support
Thanks in advance
Re: Jmp project all open reports
You can use Get Window List to get list of all the open windows inside the project and them loop over them using For Each loop
project = Open("$SAMPLE_PROJECTS\Big Class.jmpprj");
reps = Get Window List(Project(project), Type("Reports"));
For Each({rep}, reps,
	Show(rep << get window title);
