voy-voy
Open *DBF Files with Multiple import
I want to open many DBF files.
If I open every file separately then this ist no problem.
But if I try to open al files with the multiple import, then it don't work.
I get one table with the Filename in one line and it is written "Nicht unterstütztes Dateiformat" (Unsupported file format).
Could someone solve this problem?
Re: Open *DBF Files with Multiple import
Please forward this information JMP's technical support.  They will then ensure that the information gets to the appropriate developer.  Thanks for the information.
It is a good wish list item too. I don't think MFI understands DBF.
https://community.jmp.com/t5/JSL-Cookbook-Archived/Concatenate-data-tables/ta-p/82457 might be a good start for a work-around. There are a number of similar scripts using FilesInDirectory() posted here.
