Jackie_
Numbering the overlay plots
Hi All,
Is there a way I can number the overlay plots? I want something similar to the pic attached below
Thanks
Re: Numbering the overlay plots
I am going to point you away from the Overlay Plot for a couple of reasons
  1. The Overlay Plot, and even more for the real old version of the Overlay Plot, that you are using has been depleted in value and will be going away sometime.
  2.  Because of the Tree Structure of the output from the old Overlay Plot, trying to get a value to the left of the label is tricky.
Therefore I am pointing you to the Graph Builder, to a plot that looks just like your included graph.  Here is how I am handling your repest:
dt = Open( "$SAMPLE_DATA\semiconductor capability.jmp" );
gb = dt << Graph Builder(
	Size( 534, 456 ),
	Variables( X( :PNP3 ), Y( :NPN1 ), Y( :PNP1 ), Y( :NPN2 ), Y( :NPN2 ) ),
	Elements( Position( 1, 1 ), Points( X, Y, Legend( 14 ) ) ),
	Elements( Position( 1, 2 ), Points( X, Y, Legend( 16 ) ) ),
	Elements( Position( 1, 3 ), Points( X, Y, Legend( 18 ) ) ),
	Elements( Position( 1, 4 ), Points( X, Y, Legend( 20 ) ) )
(Report( gb ) << xpath( "//TextEditBox" )) << Rotate Text( "Horizontal" );
For( i = 1, i <= 4, i++,
	Report( gb )[Text Edit Box( i + 3 )] << set text(
		Char( i ) || " " || Char( Report( gb )[Text Edit Box( i + 3 )] << get text )
10 REPLIES 10
Jackie_
What version of JMP are you using?
Jackie_
JMP 15
	Size( 534, 456 ),
Jackie_
Hi @txnelson ,
Quick question: What's the syntax for selecting the whole column group (Processes) in Y axis?
Jackie_
@txnelson any suggestions?
You will have to list out all of the columns separately.  Here is the script that is generated by JMP when one has dragged the Processes group to the Y drop area, and the Site column to the X drop area.
Graph Builder(
	Size( 570, 526 ),
	Variables(
		X( :SITE ),
		Y( :NPN1 ),
		Y( :PNP1, Position( 1 ) ),
		Y( :PNP2, Position( 1 ) ),
		Y( :NPN2, Position( 1 ) ),
		Y( :PNP3, Position( 1 ) ),
		Y( :IVP1, Position( 1 ) ),
		Y( :PNP4, Position( 1 ) ),
		Y( :NPN3, Position( 1 ) ),
		Y( :IVP2, Position( 1 ) ),
		Y( :NPN4, Position( 1 ) ),
		Y( :SIT1, Position( 1 ) ),
		Y( :INM1, Position( 1 ) ),
		Y( :INM2, Position( 1 ) ),
		Y( :VPM1, Position( 1 ) ),
		Y( :VPM2, Position( 1 ) ),
		Y( :VPM3, Position( 1 ) ),
		Y( :PMS1, Position( 1 ) ),
		Y( :SNM1, Position( 1 ) ),
		Y( :SPM1, Position( 1 ) ),
		Y( :NPN5, Position( 1 ) ),
		Y( :EP2, Position( 1 ) ),
		Y( :ZD6, Position( 1 ) ),
		Y( :PBA, Position( 1 ) ),
		Y( :PLG, Position( 1 ) ),
		Y( :CAP, Position( 1 ) ),
		Y( :PBA3, Position( 1 ) ),
		Y( :PLG2, Position( 1 ) ),
		Y( :PNP5, Position( 1 ) ),
		Y( :NPN6, Position( 1 ) ),
		Y( :PNP6, Position( 1 ) ),
		Y( :PNP7, Position( 1 ) ),
		Y( :NPN7, Position( 1 ) ),
		Y( :PNP8, Position( 1 ) ),
		Y( :IVP3, Position( 1 ) ),
		Y( :IVP4, Position( 1 ) ),
		Y( :IVP5, Position( 1 ) ),
		Y( :IVP6, Position( 1 ) ),
		Y( :PNP9, Position( 1 ) ),
		Y( :NPN8, Position( 1 ) ),
		Y( :NPN9, Position( 1 ) ),
		Y( :IVP7, Position( 1 ) ),
		Y( :NPN10, Position( 1 ) ),
		Y( :N_1, Position( 1 ) ),
		Y( :PBA1, Position( 1 ) ),
		Y( :WPR1, Position( 1 ) ),
		Y( :B10, Position( 1 ) ),
		Y( :PLY10, Position( 1 ) ),
		Y( :VBE210, Position( 1 ) ),
		Y( :VTN210, Position( 1 ) ),
		Y( :VTP210, Position( 1 ) ),
		Y( :SIT2, Position( 1 ) ),
		Y( :SIT3, Position( 1 ) ),
		Y( :INV2, Position( 1 ) ),
		Y( :INV3, Position( 1 ) ),
		Y( :INV4, Position( 1 ) ),
		Y( :INV5, Position( 1 ) ),
		Y( :FST1, Position( 1 ) ),
		Y( :FST2, Position( 1 ) ),
		Y( :RES1, Position( 1 ) ),
		Y( :RES2, Position( 1 ) ),
		Y( :PNM1, Position( 1 ) ),
		Y( :PPM1, Position( 1 ) ),
		Y( :FNM1, Position( 1 ) ),
		Y( :FPM1, Position( 1 ) ),
		Y( :FST3, Position( 1 ) ),
		Y( :FST4, Position( 1 ) ),
		Y( :RES3, Position( 1 ) ),
		Y( :RES4, Position( 1 ) ),
		Y( :A1, Position( 1 ) ),
		Y( :B1, Position( 1 ) ),
		Y( :A2N, Position( 1 ) ),
		Y( :A2P, Position( 1 ) ),
		Y( :A2P1, Position( 1 ) ),
		Y( :IVP8, Position( 1 ) ),
		Y( :IVP9, Position( 1 ) ),
		Y( :DE_H1, Position( 1 ) ),
		Y( :NF_H1, Position( 1 ) ),
		Y( :ESM1, Position( 1 ) ),
		Y( :ESM2, Position( 1 ) ),
		Y( :ESP1, Position( 1 ) ),
		Y( :YFU1, Position( 1 ) ),
		Y( :VPM4, Position( 1 ) ),
		Y( :PBA2, Position( 1 ) ),
		Y( :PBB1, Position( 1 ) ),
		Y( :LYA1, Position( 1 ) ),
		Y( :LYB1, Position( 1 ) ),
		Y( :DEM1, Position( 1 ) ),
		Y( :DEP1, Position( 1 ) ),
		Y( :NFM1, Position( 1 ) ),
		Y( :PLY1, Position( 1 ) ),
		Y( :VDP1, Position( 1 ) ),
		Y( :VDP2, Position( 1 ) ),
		Y( :SNW1, Position( 1 ) ),
		Y( :RSP2, Position( 1 ) ),
		Y( :PLY2, Position( 1 ) ),
		Y( :RSP1, Position( 1 ) ),
		Y( :VDP3, Position( 1 ) ),
		Y( :PBL1, Position( 1 ) ),
		Y( :PLG1, Position( 1 ) ),
		Y( :VDP4, Position( 1 ) ),
		Y( :SPW1, Position( 1 ) ),
		Y( :VIA1, Position( 1 ) ),
		Y( :INM3, Position( 1 ) ),
		Y( :VPM5, Position( 1 ) ),
		Y( :VPM6, Position( 1 ) ),
		Y( :INM4, Position( 1 ) ),
		Y( :VPM7, Position( 1 ) ),
		Y( :M1_M1, Position( 1 ) ),
		Y( :M2_M2, Position( 1 ) ),
		Y( :P1_P1, Position( 1 ) ),
		Y( :E2A1, Position( 1 ) ),
		Y( :E2B1, Position( 1 ) ),
		Y( :NPN11, Position( 1 ) ),
		Y( :IVP10, Position( 1 ) ),
		Y( :PNP10, Position( 1 ) ),
		Y( :INM5, Position( 1 ) ),
		Y( :VPM8, Position( 1 ) ),
		Y( :VPM9, Position( 1 ) ),
		Y( :INM6, Position( 1 ) ),
		Y( :VPM10, Position( 1 ) ),
		Y( :N2A1, Position( 1 ) ),
		Y( :N2B1, Position( 1 ) ),
		Y( :NM_L1, Position( 1 ) ),
		Y( :P2A1, Position( 1 ) ),
		Y( :P2B1, Position( 1 ) ),
		Y( :PM_L1, Position( 1 ) ),
		Y( :P1, Position( 1 ) ),
		Y( :M1, Position( 1 ) )
	Elements(
		Points(
			X,
			Y( 1 ),
			Y( 2 ),
			Y( 3 ),
			Y( 4 ),
			Y( 5 ),
			Y( 6 ),
			Y( 7 ),
			Y( 8 ),
			Y( 9 ),
			Y( 10 ),
			Y( 11 ),
			Y( 12 ),
			Y( 13 ),
			Y( 14 ),
			Y( 15 ),
			Y( 16 ),
			Y( 17 ),
			Y( 18 ),
			Y( 19 ),
			Y( 20 ),
			Y( 21 ),
			Y( 22 ),
			Y( 23 ),
			Y( 24 ),
			Y( 25 ),
			Y( 26 ),
			Y( 27 ),
			Y( 28 ),
			Y( 29 ),
			Y( 30 ),
			Y( 31 ),
			Y( 32 ),
			Y( 33 ),
			Y( 34 ),
			Y( 35 ),
			Y( 36 ),
			Y( 37 ),
			Y( 38 ),
			Y( 39 ),
			Y( 40 ),
			Y( 41 ),
			Y( 42 ),
			Y( 43 ),
			Y( 44 ),
			Y( 45 ),
			Y( 46 ),
			Y( 47 ),
			Y( 48 ),
			Y( 49 ),
			Y( 50 ),
			Y( 51 ),
			Y( 52 ),
			Y( 53 ),
			Y( 54 ),
			Y( 55 ),
			Y( 56 ),
			Y( 57 ),
			Y( 58 ),
			Y( 59 ),
			Y( 60 ),
			Y( 61 ),
			Y( 62 ),
			Y( 63 ),
			Y( 64 ),
			Y( 65 ),
			Y( 66 ),
			Y( 67 ),
			Y( 68 ),
			Y( 69 ),
			Y( 70 ),
			Y( 71 ),
			Y( 72 ),
			Y( 73 ),
			Y( 74 ),
			Y( 75 ),
			Y( 76 ),
			Y( 77 ),
			Y( 78 ),
			Y( 79 ),
			Y( 80 ),
			Y( 81 ),
			Y( 82 ),
			Y( 83 ),
			Y( 84 ),
			Y( 85 ),
			Y( 86 ),
			Y( 87 ),
			Y( 88 ),
			Y( 89 ),
			Y( 90 ),
			Y( 91 ),
			Y( 92 ),
			Y( 93 ),
			Y( 94 ),
			Y( 95 ),
			Y( 96 ),
			Y( 97 ),
			Y( 98 ),
			Y( 99 ),
			Y( 100 ),
			Y( 101 ),
			Y( 102 ),
			Y( 103 ),
			Y( 104 ),
			Y( 105 ),
			Y( 106 ),
			Y( 107 ),
			Y( 108 ),
			Y( 109 ),
			Y( 110 ),
			Y( 111 ),
			Y( 112 ),
			Y( 113 ),
			Y( 114 ),
			Y( 115 ),
			Y( 116 ),
			Y( 117 ),
			Y( 118 ),
			Y( 119 ),
			Y( 120 ),
			Y( 121 ),
			Y( 122 ),
			Y( 123 ),
			Y( 124 ),
			Y( 125 ),
			Y( 126 ),
			Y( 127 ),
			Y( 128 ),
			Legend( 3 )
You did not specify if the solution required a script. Jim provided such a solution. I just want to remind you that you can interact with the axis label and edit the label directly.
Jackie_
How can I edit the axis label with the script?
