I'm a beginner on JMP, and I want to create a dynamic app.
I have create an application and I want to display on the module the open data table.
If i create a script like that :
ds = Open( "C:\Users\rroustan\Documents\test.txt", invisible );
New Window( "Example",
H List Box( button = Button Box("test")),
H List Box( dtBox = ds << New Data Box() ));
It will work with no problem, but I want to show this table on a panel when I click on the button.
I try this :
New Window("test",
btShow = Button Box("Show table",
pTable <<Launch(
ds<<New Data Box())));
But still not working.
Someone have an idea please?
If you want the table in the same window as the button, try this. It creates an empty panel box (you could use a tab box, a list box, or whatever container you'd like), and appends the table when you click the button. I put in code that also looks to see if the panel box already has something in it, and deletes if it does. This allows you to later open a different data table, click the button, and replace the old table with the new one, instead of adding under the old one.
ds = Open( "$sample_import_data/Bigclass.txt", invisible );
New Window( "test",
btShow = Button Box( "Show table",
If(IsScriptable(pTable<<Child), (pTable<<Child)<<delete);
pTable << Append(ds << New Data Box())
pTable = Panel Box("Table")
After you run the above, run this line, to open a different table, and then click the button in the window.
ds = Open( "$sample_import_data/Animals.txt", invisible );
Your variable pTable is undefined.
The New Data Box needs to be inside a New Window to be displayed. Try this:
New Window( "test",
new window("Example", ds << New Data Box() )
New Window( "test",
