Jackie_
Need help with Column formula
I want to convert this loop into an equivalent column formula
// Assuming Column B is column 2
testColumn = Column( dt, 1 );
llCol = dt << New Column( "LL Limit_7.5", Numeric );
ulCol = dt << New Column( "UL Limit_7.5", Numeric );
// Loop through each row starting from row 20
For( i = 20, i <= N Rows( dt ), i++,
	data = testColumn[1 :: i]; // Get values from row 20 to the current row
	q1 = Quantile( 0.25, data ); // 1st Quartile
	q3 = Quantile( 0.75, data ); // 3rd Quartile
	// Factor value is 6
	factorValue = 7.5;
   // Calculate ll and ul
	llx = q1 - (q3 - q1) * (factorValue - 0.675) / 1.35;
	ulx = q3 + (q3 - q1) * (factorValue - 0.675) / 1.35;
   // Set the calculated values in the new columns
	llCol[i] = llx;
	ulCol[i] = ulx;
I tried but it doesn't seem to be correct. Any advice?
newColExpr = Expr(
	llCol << Set Formula(
		If( Row() >= 20,
			Col Quantile( 0.25, Expr( TestColumn( 1, Row() ) ) ) - (Col Quantile( 0.75, Expr( TestColumn( 1, Row() ) ) )
			-Col Quantile( 0.25, Expr( TestColumn( 1, Row() ) ) )) * (Expr( factorValue ) - 0.675) / 1.35,
	ulCol << Set Formula(
		If( Row() >= 20,
			Col Quantile( 0.75, Expr( TestColumn( 1, Row() ) ) ) + (Col Quantile( 0.75, Expr( TestColumn( 1, Row() ) ) )
Eval( Eval Expr( newColExpr ) );
Re: Need help with Column formula
You can do something like this but I'm not exactly sure if it is the best way to go with this
dt = Open("$DOWNLOADS/data_table.jmp");
dt << New Column("Low", Numeric, Continuous, Formula(
	As Constant(
		factorValue = 7.5;
	If(Row() < 20,
		m = :Data[1::Row()];
		q1 = Quantile(0.25, m);
		q3 = Quantile(0.75, m);
dt << New Column("High", Numeric, Continuous, Formula(
	As Constant(
		factorValue = 7.5;
	If(Row() < 20,
Could you explain what you wish to do?
Jackie_
Calculating PAT limits. I want to link the formula with a table variable, which will allow me to vary the factor value from a GUI
	As Constant(
		factorValue = 7.5;
	If(Row() < 20,
	As Constant(
		factorValue = 7.5;
	If(Row() < 20,
Level XIII
Interesting, for Col Quantiles, it's  first the column, then the Quantile.
Besides that, Col Quantile will take all rows - not rows 1::currentRow
-> will result in a constant value.
newColExpr = Expr(
	new column("llCol" ,Formula(
		If( Row() >= 20,
	new column("ulCol" ,  Formula(
		If( Row() >= 20,
 Eval(Eval Expr( newColExpr )) ;
