pmroz
Need Uneven Intervals on X Axis in Graph Builder (value labels didn't work)
Hello all,
I've seen similar questions but nothing quite like this one.  I have data that looks like this:
PeriodStart DateEnd DateRF
101Jan200531Dec20050.1
201Jan200630Jun20060.2
301Jul200631Dec20060.3
401Jan200731Dec20070.4
The Period column consists of consecutive integers, usually starting at 1.  As you can see the Start Date column has uneven increments.  Users want to see a graph of RF vs Period:
However the analysis we're doing is based on the Start Date column.  That graph looks like this:
I'd like to have something like the second graph, only with Period numbers on the X axis, unevenly spaced.  I tried setting value labels for Start Date but when dragged Start Date onto the X axis it ignored my value labels.
Thanks for any suggestions!
Peter
KarenC
Re: Need Uneven Intervals on X Axis in Graph Builder (value labels didn't work)
Peter,
I "tricked" graph builder into doing this:
I used reference lines with 0% color with labels and then changed the increment on the x-axis until is was such that no dates plotted.  So if you can script that maybe it would work. It would be a "pain" to do for a large dataset or more than once. It would be better if value labels would translate to the axis labels.
Ah but this is what you might have already found.....so I have nothing for you.
Good Luck
Karen
ron_horne
hi PMroz​,
are any of the comments on this link of use?
uneven intervals on the axis
Ron
pmroz
I looked at that before posting and the best suggestion was from Xan: add labeled reflines for the "real" labels.  Was hoping for something easier.
KarenC
Peter,
Good Luck
Karen
pmroz
Thanks Karen.  I was headed in that direction but your answer provided good clarification.
