BookmarkSubscribe
d_barnett
Naming of Subset with Original File name with _New appended
I have an 'original data table that I take a subset from and wish to rename the new file with the original filename but with _new appended to the filename.
e.g.
Original filename
001751-00001-1-1-VAM
after subsetting it I want to rename it
0001751-00001-1-1-VAM_new
I  thought that the rename file script would do it but I can't make it pick out the name of the original file, append then save the file.
any help would be most appreciated.
Regards
David
Jeff_Perkinson
Re: Naming of Subset with Original File name with _New appended
Would something like this work?
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
dt << select where( :sex == "M" );
dt << Subset( Output Table( Word( 1, dt << get name, "." ) || "_new" ), Selected Rows( 1 ) );
It uses a reference to the original data table, dt, and the get name message to get the name and appends "_new" as you requested.
-Jeff
-Jeff
DaveLee
jeff.perkinson​'s reply was spot on except there should be Selected Rows(1)
Jeff_Perkinson
Yikes! You're right!
I've edited my reply to correct this. Sorry!
-Jeff
